Configures the number of Hello+ messages required by the specified ELSM-enabled ports to transition from the Up state to the Down state.
| port_list | Specifies the port or ports for which the ELSM hold threshold should be configured. |
| uptimer_threshold | Specifies the number of Hello+ messages required to transition from the Up- state to the Down state. The default is 6messages, and the range is 3 to 60 messages. |
The default is 6 Hello+ messages.
The ELSM up timer begins when the ELSM-enabled port enters the UP state. Each time the port receives a Hello+ message, the timer restarts. Up timer is Uptimer_threshold * hello timer. When the Up timer expires, it transits from UP state to DOWN state.
This command was first available in ExtremeXOS 12.0.
